Rear wheel wobble
Old May 6, 2017 | 1:10 PM
sicko243@yahoo.com's Avatar
Default Rear wheel wobble
I put new leaf springs on my 06 silverado 1500 and and when I put the tires back on I noticed my rear passenger tire wobbles up and down by hand like a it would if a wheel bearing was bad I'm not sure how the rear wheel bearing works or of it's even a wheel bearing back there, I have drum brakes if that matters at all. How can you tell if it's the bearing?
Old May 6, 2017 | 4:00 PM
Did you notice if it was wobbling before you changed the spring? If the wheel bearing was good before the change, it wouldn't be bad after changing a spring. Look for something else such as something being left loose.
Old May 6, 2017 | 5:17 PM
I didn't try to wobble it before I did my springs but my wheel is tight.
