RMS leaks
Old Jun 1, 2024 | 8:21 PM
Para's Avatar
Default RMS leaks
Originally Posted by Mike Sigmond
I have access to the individual sections to it, is there a specific section you need. Its a database I have from my old job that has all vehicles makes & models , and they are factory information.
I need the model type, engine size and the trans info to look it up.
I realize this is a major blast from the past but I was wondering if this offer may still stand?
I was wondering when replacing a transmission if the factory service manual advises replacing the rear main seal on the engine? I had a transmission replaced a year ago by a shop and they did not replace the seal which now leaks. I am surprised, considering the vehicle has 150K+ miles on it, that the shop didn't ask if I wanted it replace or just go ahead and do it. It would have been $60 at the time while the transmission was out and now is $1,500. Thus, i was wondering if the factory service manual makes any recommendations.
It is a 2006 silverado 1500 LT 5.3 4x4, i believe engine code T. Any assistance you can provide is gratly appreciated.
Thanks!
Old Jun 1, 2024 | 10:09 PM
Welcome to the forum.
I moved your question to its own thread, because Mike will not respond to you. If you click his name you will see that hasn't been to the forum in 12 years. Please do not revive 15 year old topics.
Anyway it's not standard procedure to replace RMS with the transmission. If the leaks isn't bad (ie dripping on your driveway) then I would just leave it alone.
The service manual is available for free on charm.li
Good luck.
Old Jun 1, 2024 | 10:55 PM
Para's Avatar
Good luck.
Thank you very much for the help! Apologies for reviving old post and engaging an inactive member!
4L60E SS
Oct 5, 2017 12:07 PM
rollie88
Nov 21, 2015 12:54 PM
jipjoh
Dec 7, 2014 6:08 AM
jayqc
Jul 16, 2012 12:02 PM
Dugmontis
May 21, 2009 4:14 PM
