Scanner wont connect to tccm
Old Dec 10, 2024 | 7:06 AM
Bigrig1284's Avatar
Default Scanner wont connect to tccm
I have a 2000 silverado 1500 and when I put a scanner on it doesn't connect to the tccm. I just bought the truck and the 2high and 4lo buttons were lit up so I bought an encoder shift motor and now all lights are lit up on the switch. Then I plugged a scanner in it and it says no communication with the tccm and the hvac modules. Any help would be greatly appreciated.
Old Dec 11, 2024 | 10:26 AM
chem_man's Avatar
15 Year Member
You likely need a professional level code reader/live data scanner in order to connect to and read the TCCM, HVAC module, ABS module, etc. Most consumer level/DIYer OBD II code readers/scanners only connect to the ECM/PCM.
Old Dec 12, 2024 | 12:01 PM
Oldcat's Avatar
Check your fuses for the TCCM. There is a 4WD fuse in the instrument panel fuse box and an ATC fuse in the underhood fuse box.
Old Dec 12, 2024 | 7:29 PM
Bigrig1284's Avatar
Yes sir I have an autel maxisys ms909 and it wouldn't communicate with the tccm or the hvac. I have checked for power and ground to both and checked and cleaned all fuses. Cleaned and retightened the grounds. New encoder motor and switch. Just wondering if I missed anything before I buy a module
thank you all for any help
Old Dec 31, 2024 | 8:52 AM
Bigrig1284's Avatar
Default Loose pin connection
Turns out it was an intermittent loose orange power wire into a connector in the back of the i/p fuse block. Always check your powers and grounds repeatedly and give them a tug.
42Schied
Nov 8, 2019 1:21 PM
Ccatx3
Jan 20, 2017 11:43 PM
whaley01
Dec 6, 2016 6:17 AM
Texcowboy
May 28, 2013 11:04 AM
harrydtjr
Oct 15, 2009 8:40 AM
