Service 4wd Light on dashboard
Old Mar 29, 2017 | 8:19 AM
georgelb's Avatar
Default Service 4wd Light on dashboard
Hello,
Hope this is the right place to post this. If not, my apologies.
I am having a 4WD issue, and I have tried several fixes from my father in law who is a mechanic, and Google and Youtube videos, and nothing is seeming to work to fix the issue. Hoping someone on here has experienced the same issue as described below, and can help me out.
I have a Chevy Silverado 1500 4x4 pickup. I live in Northern Virginia. When we had our last snow, I went to a clients house to remove some junk from their property. They had a dirt/gravel road, and still had some snow and ice on it. So I went to engage 4x4 to ensure I could get through it alright. When I hit the 4HI switch, on the selector, you could hear the truck switch into 4HI, but then the lights on the selector switch went off completely, and a "Service 4WD" light came on my message center on the dashboard. I figured something was wrong with it, so I tried to switch back to 2 wheel drive, because my truck already has 4 wheel drive issues (previous owners did something to it, and so when you go to make some turns in 4WD, it makes it seem the wheels are to their max turning point and will jerk).
Unfortunately, the truck would not go back into 2WD at all. After we did the job, I went to a nearby gas stations. Called my father in law and he said that it was stuck in 4WD and go back 6ft and it should disengage. I did that, and it seemed to work, as I could turn the turn in either direction, without issue.
I was able to make it back without issue. So, I assumed that everyone was fixed and it was nothing to worry about.
Went to get in it the next day, and still no lights on the selector. Didn't think anything of it, until I went to turn, and my truck was jerking pretty good (because of the previous owner screwing something up).
That is when my father in law told me that it was most likely the selector switch, but unfortunately, it could be 1 of 3 other possibilities as well. He told me to switch out the selector switch first, as it was the cheapest option, and generally the cause of the SERVICE 4WD light being on.
Bought a new one from Autozone. Installed it that evening, and when I turned the truck on, there was white lights for the selector switch, and not orange like my old one, but again didn't think much of it. Tried switching it into 2WD and NOTHING happened. Tried 4LO and Auto 4WD and again NOTHING happened. I figured I try again the next morning.
Got in it the next morning, and turned the truck again, and as luck would have it, no lights on the selector switch, except for a faint white light for 2WD.
So, I took it for a test drive. It is driving slightly better, but still has the turning issue to a degree but an improvement over how it was.
When I get back home, I go to back it up, and realize that now my truck as a reverse issue, and does the same motion, as when I make a turn.
At this point, I am at a loss, and so is my father in law (which never happens) as to what the issue is.
Everything I can find online via Google and Youtube, all say that the Service 4WD light on dashboard is for the selector switch and once changed, it will all work again, and no message. Didn't happen for me. Most guys on the youtube videos, even said that they changed out the transfer case, actuator, and the module thing behind the selector switch, but eventually changed the selector switch which was the issue to begin with.
At this point, I am at a brick wall. I dont have the money to replace it every component for the 4WD on my truck, as one part alone is around $1000. Only thing I can think of, is perhaps the selector switch is no good, even though it is new.
Hoping someone can give some insight or idea that we havent thought of yet.
Apologies for the LONG post. Just wanted to ensure that I fully explain everything that has happened so far.
Old Apr 3, 2017 | 1:25 PM
Joe P's Avatar
The 4WD not shifting problem is a known issue & you will find several posts about it if you do some searches on this site. No need to repeat them again!
Last edited by Joe P; Apr 3, 2017 at 1:25 PM. Reason: left part of my response out
Old Apr 8, 2017 | 4:06 PM
phow's Avatar
Cool Service 4WD
I dealt with an intermittent SERVICE 4WD message associated with none of the lights on the panel working. I changed the switch panel to no avail and the TCCM to no avail. (It's right above the parking brake pedal, btw.) Then it began working good for a week, then failed again.
I located the solenoid connector at the transfer case (above transfer case, slide under from driver's side, need two hands to separate the connector) and the solenoid for the front axle (on the right side, just above the forward, rh corner of the protective pan). I disconnected both of these connectors and blasted them with a new can of electric contact cleaner. I put the connectors together and took them apart several times to clean surface of the contacts, then blasted them again. Let them dry for about 30 minutes.
All has been normal since. I wish I had cleaned the connectors first.
Old Apr 11, 2017 | 9:42 AM
jrow8162's Avatar
Sounds like the actuator is bad. Common problem on those trucks. Replace the actuator and it should come out of 4WD. The grinding noise in 4WD is normal.
Old May 3, 2017 | 10:34 AM
99 Silverado 3 door's Avatar
I had a similar problem with my 99 Silverado 5.3 liter. The 4 WD switch went out and the service light came on. Our local chevy dealer put in a new switch and cleared the codes and I haven't had a problem since. This was about 3 years ago. The lights on the new switch are a lot dimmer than the original and my dealer said that is because the earlier switches with the brighter lights tended to short out the switch. The dimmer lights create less heat and use less juice he said. Hope this helped.
Old May 10, 2017 | 7:32 PM
Sabireley's Avatar
I cleaned the ground connection under the drivers door on the outside of the frame and it worked immediately.
Old Jul 31, 2017 | 12:17 PM
codec3003's Avatar
Default Cold solder connections on selector switch
I removed selector switch and re soldered all connections to solve my check 4 wheel drive message on dash 2001 z71.
