side mirrors
Old Apr 1, 2016 | 9:45 PM
bojowaggie's Avatar
Default side mirrors
Hello all,
I just purchased a 2004 Chevy 2500 HD Duramax.
It's got aftermarket side mirrors and i'd like to put the factory ones back on so i'm wondering if anyone knows what the factory ones are and what they looked like..
When I do a search for OEM I get a couple different ones.
I'm sure the factory were heated but did they also have turn signal in them??
Thanks,
--Brandon
Old Apr 3, 2016 | 5:55 PM
if you don't mind the wait for shipping or buying Chinese....this site has some pretty good deals. but you better know what your ordering.
aliexpress.com
they came will several different mirror options from factory. the rpo code is in the glove box will tell you what it originally was equipped with.
the towing retractable, folding mirrors were a $1000 each. Once the plastic gears stripped, people installed the power, double glass (with manual slide out) version. the latter provides better view imo
pretty sure the connectors were the same but the extendable may of had a second connector?? plug the door panel and verify the connectors with whatever you buy. anything the 2009 new body style to 2006 should fit the door mount.
Old Apr 18, 2016 | 4:35 AM
iluvchevy's Avatar
The part numbers for oem mirror are 15124827 and 15124828. For oem towing mirrors-- 15904034 and 15904035.
