Silverado 2004 transfer case stuck in neutral
Old Dec 20, 2021 | 1:09 AM
  #11
Lambert2828's Avatar
Default I know the problem. Anyone still have this problem?
Originally Posted by BigGdeKC
  1. Ever find out what was wrong with it? I’m having same problems
  1. I know the problem. Let me know if anyone is stuck in neutral. I'll explain the best way to help get transfer case out of neutral.
Old Jan 14, 2022 | 10:54 PM
  #12
kingrump's Avatar
Default yes im having the same issue.
Originally Posted by Lambert2828
  • I know the problem. Let me know if anyone is stuck in neutral. I'll explain the best way to help get transfer case out of neutral.
  • How do I get the transfer case out of neutral please help
Old Feb 2, 2022 | 7:55 PM
  #13
Warder65's Avatar
Default I'm having the problem
  • What is the problem I'm having it just put new motor on and it won't shift
Old Mar 13, 2022 | 7:20 PM
  #14
Bmorrow85's Avatar
Default 06 chevy suburban with same issue
I have a 06 chevy suburban 1500 4x4, I replaced the transfer case encoder motor and the 4wd selector switch and just yesterday I replaced the Transfer case control module. It's still stuck in neutral and won't shift out at all. I barley have forward gears, no reverse and park is barley there. How do I fix this issue. I'm at a complete loss, any help would be great!
Old Feb 14, 2023 | 10:11 AM
  #15
Penguin88's Avatar
  • I am currently having this issue with my 2005 GMC Sierra 5.0 SLE truck won't move I can hear the TC trying to shift out of neutral while the selected position light flashes but then goes out without shifting . I need this thing back on the road ASAP any help is much appreciated
Old Jul 10, 2023 | 8:21 PM
  #16
alexisolivia's Avatar
Default How?? Please help.
  • Please help! I’ve tried everything. I’ve replaced every part. so I replaced the 4 wheel drive motor 2 Wheel Dr. modem , transfer case modem, transfer case modem push button. 4 wheel drive pushbutton four-wheel-drive under the dash modem, under the dash modem cleaned all the ground cleaned all the ground, checked all the fuses and checked all the fuses. I’m at a loss.
Old Dec 19, 2023 | 8:28 PM
  #17
lucascam05's Avatar
Default Help
Did anyone fix this problem?? I can’t figure it out either and have all the same problems
Old Dec 19, 2023 | 8:34 PM
  #18
lucascam05's Avatar
Default Help
My transfer case is stuck in neutral. The motor on the case was just replaced before I bought the truck. I replaced the switch, the control module, (I need to program that still) I cleaned the grounds, and replaced front actuator. Switch still says stuck in neutral and I’m getting service 4x4. I can hear the motor trying to do something while I press the buttons but no shifts happen. Any ideas? Maybe I need a different shift motor again? Faulty? Help
Old May 9, 2026 | 4:54 AM
  #19
JDSmith6600's Avatar
  • Please help!! Stuck in neutral
Old May 11, 2026 | 5:39 AM
  #20
Shaymus1968's Avatar
  • Is the fuse blown? ATC or TREC, Start out simple first. If it's not, pull that fuse anyways and leave it for 15 min to reset the system.
