Silverado Break problems
Old May 26, 2016 | 8:25 PM
under the hood's Avatar
Default Silverado Break problems
I have replaced most the front brake lines and the master cylinder, the back brakes are working the front aren't, I have been working on this for two weeks , any help would be appreciated , Thanks . By the way this is a 2002 Silverado 1500
Old May 26, 2016 | 9:05 PM
does the brake pedal feel spongy or go deep to the floor? does it firm up when pumping the pedal?
Old May 27, 2016 | 5:13 AM
Doesn't firm up, I can bleed the back breaks fine, but not the front, they never go to the floor ,
Old May 27, 2016 | 7:56 AM
cleveland63b's Avatar
so you're not getting fluid out of the front when you try to bleed? Did you bench bleed the master cylinder? I would try opening a front bleeder and see if it will gravity bleed or if you can put vacuum on it to get fluid flowing.
Old May 28, 2016 | 10:32 AM
hicksvilleshick's Avatar
Bleeding not complete.
Clevelands suggestions are solid.
Old May 29, 2016 | 8:06 AM
Been there , done that, Front caliber moving slightly, It just won't pump up
Old May 29, 2016 | 8:56 AM
bandit_601948's Avatar
there should be a porporation valve on the frame and it might be bad !
