Old July 23rd, 2015, 4:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
Silverado Check Engine Light
Old March 28th, 2011 | 6:54 PM
  #21
jstutz101's Avatar
Add me to the list of "Tighten Fuel Cap" victims. After reading the replies I was curious if this would normally be covered under the standard 5 year/50,000 mile warranty coverage?? I am at 95,500 miles and my truck is a 2007.
Thanks!!
Jeff
Old July 4th, 2011 | 2:40 PM
  #22
GM Fixer's Avatar
where is the open vent solenoid valve, My truck has the same problem.
Old July 5th, 2011 | 11:54 AM
  #23
btandy's Avatar
Back corner of the fuel tank up towards the top.i have an 07 and replaced it myself for $230 and about an hour of labor
Old July 6th, 2011 | 12:31 PM
  #24
GM Fixer's Avatar
Thanks, I have cleaned it out and today should be the test
Old July 13th, 2011 | 7:19 PM
  #25
mainer207's Avatar
2004 Chevy Silverado, 4.3L check engine light came on about every 2 months, small evap leak, replaced the gas cap, no luck in fixing the problem. Mine did not change the fuel mileage, so I just clear the code every two months. Started having problems when the vehicle had about 180,000 miles on it.
Old July 17th, 2011 | 7:13 PM
  #26
bamaboy69's Avatar
Default P0442 problem
I have a 2009 Silverado Crew Cab LS 5.3L with a check engine light on again for the third time since March 8, 2010. First it was a P0454, where the dealership replaced the fuel tank pressure sensor because it was severely corroded. The mileage was 31,971. The next time the check engine light came on was July 4, 2011. This time a code P0449 came up. The dealership said the fuel tank vent solenoid was not venting and they needed to install a new vent solenoid kit. The mileage was 69,532 this time and this was not covered under the emissions warranty nor the powertrain warranty. I was a little ticked since this was an emmisions code. Needless to say I paid them to replace it, $481.22 later. Not a week goes by and the light comes on again(July 17, 2011). This time a P0442 code comes up saying there is a small leak in the EVAP System. I am checking the work done by the dealership and will let you know the outcome. Obviously GM has a big problem with their fuel systems on various makes and models. I am a loyal Chevy Man but getting very frustrated with these problems on a truck that's not even 2 1/2 years old yet.
Old July 17th, 2011 | 8:28 PM
  #27
kevinkpk's Avatar
I have been a Chevy man for several years, nowadays it seems that GM in general sux. Next new car I buy will be a Ford. Now that Obama bought the UAW vote, they still CANNOT build a decent vehicle
Old August 22nd, 2011 | 6:56 PM
  #28
gharris's Avatar
Default gharris
Have you checked the canister purge soleniod, I have same problem, it's around $50.00 at dealer
Old September 5th, 2011 | 2:19 PM
  #29
DBaldChevy's Avatar
Default "Service Engine Light"
I have a 1993 Chevy Silverado K1500 and I am looking to rebuild it to better than factory. However I continue to have the "Service Engine" light come on with every key turn and it is using some serious fuel. I have the 350 cu in. in it and I am only getting at best 10mpg. Can anyone point me in the right direction?
Old November 30th, 2011 | 5:54 PM
  #30
dazzle313's Avatar
Default po445 code
My 2007 silverado has a po445 code. I changed the vent solenoid and put it where chevy recomended. I drove it about one mile and the light came back on. Still have the same code. Should i change the purge valve?
Quick Reply: Silverado Check Engine Light
