Stalling when turning
Old Apr 13, 2020 | 11:02 PM
Matthew Lennon's Avatar
Default Stalling when turning
2003 Silverado 4.8L, it was stalling out and the lights dimming at idle, tested alternator came back bad so put a new one in it, this was 2 days ago. Now there is no rough idle, but when I am in drive and go to turn slowly, at idle, the truck stalls, no power loss at high speed or even when backing up. Anyone have any suggestions on what it could be?
Old Apr 15, 2020 | 9:39 AM
Gumby22's Avatar
Pull the intake tube off the throttle body and inspect for carbon build up around the edges of the plate. If it’s bad enough it can restrict air flow at idle and/or cause the plate to stick, so when a need for power is required (such as turning the wheel) the PCM can’t adjust the TB to compensate.
If it’s clean, there may be an ignition switch wire on the column that’s getting stretched/grounded when turning and causing an intermittent open.
Check for codes even if the light isn’t on - intermittent problems can often take several ignition cycles to trigger the light.
Old Apr 18, 2020 | 9:10 PM
Ended up being a bad alternator from advanced, replace alternator truck runs fine.
Old Apr 28, 2020 | 8:51 AM
Irish_alley's Avatar
I'm here for the party
never heard of an alternator causing stalling issues. maybe a poor connection on the battery or alternator that would only happen when turning. knew of another chevy truck that would stall when turning turned out to be a poor ground on the engine
JCC
Chevelle & El Camino
Aug 17, 2014 3:00 PM
Sethyates72
Feb 1, 2014 7:53 AM
moto762
Aug 4, 2013 5:59 PM
chevylumina
May 29, 2013 9:38 PM
Spike44
Jan 21, 2005 11:58 AM
