Taillight Issue
Old Aug 1, 2018 | 12:00 AM
12151791's Avatar
Default Taillight Issue
Hey guys, first post.
2001 Silverado, 4.3l, fleet truck
Having some taillight trouble. Passenger side nighttime taillight doesn't work, but everything else does, include brake lights both sides. Unplugged the passenger side taillight from the underside receptacle, but it will blow the fuse when I turn the key every time. Looked for any rubbed wires anywhere, couldn't see any, but having trouble seeing over the gas tank. Connections look good, bulb is fresh.
Any ideas?
Thanks
Old Aug 1, 2018 | 12:05 AM
12151791's Avatar
Default Additional info
Also tried a different receptacle for the backside, same issue.
Old Aug 1, 2018 | 1:27 AM
oilcanhenry's Avatar
Probably a corrosion issue. You need to make sure your lights are getting a good ground. Dielectric grease will keep this from happening again.
Old Aug 1, 2018 | 1:39 AM
12151791's Avatar
Alright, I'll give it a look, thanks.
