Transmission fluid and filter change problem
Old Sep 18, 2017 | 11:21 AM
Doomsdaychevrolet00's Avatar
Default Transmission fluid and filter change problem
After doing a transmission fluid and filter change on my 2000 1500 silverado 4wd when I press the gas to the floor the trans will not kick down and pick up speed. Instead it just slowly climbs up to speed. 1st 2nd and 3rd work manually. Fluid level is at approximate level. Never had an issue until after maintenance. Any suggestions?
Old Sep 18, 2017 | 3:38 PM
kevinkpk's Avatar
What else was done?
Old Sep 18, 2017 | 3:42 PM
Nothing. Everything work just fine until this. After putting in the new transmission fluid and letting the truck idle for a little bit before test driving when I test drove it is when I noticed. I didn't flush the trans was told I should've.
Old Sep 18, 2017 | 3:50 PM
kevinkpk's Avatar
Do you have any service 4 wd lights?
Old Sep 18, 2017 | 3:58 PM
I do have 4wd but no lights on or anything
