What brand plugs and wires that won’t break the bank.
Old Apr 21, 2020 | 9:07 PM
thadmaroon's Avatar
Default What brand plugs and wires that won’t break the bank.
05 Silverado Z71 crew cab 4WD
Bertha just turned over 103,000 miles, now she’s studerring.
what brand plugs and wires are common now day?
do I need to change coil packs?
THANKS
Thad
Old Apr 21, 2020 | 10:28 PM
chem_man's Avatar
15 Year Member
First, have you scanned for any codes?
Regarding spark plugs, I would go with an ACDelco spark plug, likely a double platinum (same kind that the factory put in). These engines don't like non-ACDelco plugs. You could always go with the equivalent NGK spark plug as the ACDelco plugs are manufactured by NGK. Oh yeah, watch out for too good to be true ACDelco spark plug pricing on ebay as they are likely counterfeit plugs.
For spark plug wires, I have had good luck with Standard Motor Products, BWD Select, and Carquest Premium spark plug wire sets. Just make sure you get the correct set which is dependent upon the coil used from the factory - a square coil or a round coil. There will be number stamped into the coil right above where the spark plug wire plugs into that you can compare to the ACDelco replacement coil and find out if it's a square (or Mitsubishi) coil or a round (Delphi) coil.
As far as replacing the ignition coils go, if the engine is running fine and there aren't any misfire codes, then they do not need to be replaced. The factory coils are pretty stout and can last a long, long, time.
Good luck (from an Omaha native)!
Old Apr 22, 2020 | 7:41 AM
Welcome from Florida. I also stick with ACDelco plugs. They always look good after 100K, so why change to a different brand.
Blindsight
24
Mar 6, 2021 5:27 AM
alan07
Nov 10, 2016 3:11 PM
Bedo
Nov 14, 2012 11:26 AM
chevy619
Aug 21, 2012 5:33 AM
justinhalverson56
Mar 8, 2010 9:19 PM
