07 Silverado Lt horn issues
Old Oct 30, 2018 | 11:17 AM
richard george's Avatar
Default 07 Silverado Lt horn issues
My 07 Silverado has an issue with the horn blowing when I turn ignition switch on however it does not blow while ignition is off and seems to function normally with the lock function of key remote, I have removed fuse and replaced with same results horn works perfectly at steering wheel with ignition off and with remote and then when ignition turned on it blows as if I'm pressing the switch.... Any ideas ?????
