08 Silverado 1500 cranks but won’t start
Old Aug 1, 2021 | 8:07 PM
nicoled29's Avatar
Default 08 Silverado 1500 cranks but won’t start
Went over a huge bump and the entire dash lit up and stayed that way until I got home. After that, the truck wouldn’t start again. It cranks but doesn’t start.
I can, however, get it started by commanding it on with a scan tool.
So far, I’ve replaced:
-Igniton switch
-ECM
-Fuel Pump
-Spark Plugs
-Fuel Pump Control Module
-Battery
No further codes or errors are showing with one exception: impact sensors. (Which are cracked in half) I’m not sure if for some reason that may be part of the issue but I doubt it.
I’m hoping for some advice as I’ve really run out of ideas from here. Thanks in advance!
Old Aug 2, 2021 | 10:23 PM
oilcanhenry's Avatar
-Igniton switch
-ECM
-Fuel Pump
-Spark Plugs
-Battery
Sorry you had to buy an ECM. I will assume you've checked the simple stuff like ignition spark?
rxsly
2007 - 2013 (GMT900)
Mar 21, 2021 9:19 AM
artimious7
Dec 15, 2020 5:10 PM
ncjess35
Jul 3, 2020 12:29 AM
mrk1957
Mar 12, 2011 7:48 PM
bbullsj
Jun 27, 2007 8:37 PM
