09 Silverado starting issue
Old Mar 24, 2019 | 6:05 PM
Tbarb521's Avatar
Default 09 Silverado starting issue
Hey Guys,
Im in a bad spot. We were supposed to trade in our truck today and almost hilariously it doesn’t want to start. I have tested the starter and it works fine. It is a 09 Silverado 5.3. The battery is good. All of the fuses in the engine compartment are good. Does anyone know where I can find a wiring diagram for the starting circuit?
Old Mar 24, 2019 | 8:31 PM
oilcanhenry's Avatar
Originally Posted by Tbarb521
Hey Guys,
You need to check the basics: Fuel and Fire to the cylinders. Have you hooked up a scantool yet? Post any OBD II codes here so we can help you out.
Old Mar 24, 2019 | 8:59 PM
Tbarb521's Avatar
Thanks oilcanhenry. This is a no crank issue. The starter solenoid isn’t getting any voltage. I am chasing an electrical fault. What I need is a starting circuit diagram so I can methodically go through the components. I am thinking it’s an anti theft system issue. The neutral safety switch is good, the ignition switch is good, all of the relays are good, the starter is good, the battery is good. Does anyone know if there is a way to bypass the security system so I can rule it out of the equation?
