Old Jul 24, 2015, 5:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
2008 5.3l AFM "Blown" Lifters & Camshaft $$$$
Old Jun 2, 2020 | 12:58 PM
  #311
Originally Posted by David Zacharias
So my check engine light come on and off sporadically... ive read the code everytim . Its has been 1 of two codes. P300 or p301. P301 had popped up a couple of time so i changed my plugs and wires. (All Plugs gapped at 40) check engine light had turned off pretty much right after doing so, so i thought i fixed the issue.. but after driving a bit sitting at a red light. I noticed (also could see in the rpm needle) i still had a slight misfire. The next day my check engine light popped back on. (P300) so now im at a random mulitiple misfire.. so i had a mechanic run the codes on a GOOD scanner that can watch the engine perform in real time.. it was showing no codes. UNTIL! He pushed the throttle and up pops p301 almost instantly. So that day i replaced my coil pack.. on cyclinder 1 only, temporarily with a cheap 35 dollar coil pack just to see if it fixed the issue. Check engine light turns off. 2 days later. Check engine turns back on.. 3 days later turns back off. As of right now the light is off.. but at an idle i can still feel a slight misfire..
Now that you have the full story.
My question is being that i have replaced the plugs, wires, and coil pack on cylinder 1 (being 95% of the time the code was p301) what are you thoughts on it being a sticky injector? Ive tried lucas injector cleaner/fuel treatment.. eh,, i wouldnt say i saw a change.. engine still slightly misfires.. no check engine light.
Which cylinder is the misfire? If 1,3,5 or 7 it could be impending AFM failure, might check compression on all cylinders.
Old Jun 2, 2020 | 1:31 PM
  #312
David Zacharias's Avatar
[QUOTE=in2pro;448619]Which cylinder is the misfire? If 1,3,5 or 7 it could be impending AFM failure, might check compression on all cylinders.[/QUOTE
The code has been p301, so cylinder #1. I will take that into consideration thank you... i think i will replace the injectors for now. After that inwill definitely check the compression... even if it fixes my misfire.. ill give it a look anyway
Old Oct 26, 2020 | 5:36 PM
  #313
Heidi Peakayepy's Avatar
Default Replaced all Lifters, P0301 code, then less than 1000km later, same thing....
August 22, 2020:
- after 3 hrs on the highway, CEL blinking.
- Scanned P0301 code at 297050km or thereabouts.
- Changed Coil, spark plug for AFM cylinder 1, no change, still missing.
- Engine very rough due to misfire.
- Repair done at 297131: problem diagnosed as Cylinder 1 AGM lifter collapse. Entire driver side bank lifter and head gasket and other gaskets replacement. Camshaft OK, no wear.
Oct, 24, 2020:
- Tahoe at 298000km or thereabouts.
- No issues, noticed what I think was chevy shake at or above 110kph, but would be on or off.
- Same thing that was the warning sign the first time.
- Truck rested for 2 days before next use.
- On the highway for 1.5 hours going 110kph or so, CEL comes on and blinks, but there is no sign/shake of a misfire.
- Read P0301 code AGAIN (this lifter was replaced), as well as P0521 code (At this point I'm super pissed that the repair didn't change anything)
- Pulled over, stopped the engine.
- Started again, no problems. Then CEL blinks on again, and the Oil Light blinks.
- I notice the oil pressure gauge steadily and quickly falling to 1/4 as I'm driving on the highway.
- OBComputer tells me to immediately stop the engine due to dangerously low oil pressure.
- I check oil levels, all OK. I start driving again, and oil is perfectly within the normal range, then 10 minutes starts steadily falling again, to 1/4 on the gauge, and CEL starts blinking again. I pull over, repeat an engine stop again, get back on the highway, and then go. CEL stays on solid but no longer blinks, oil pressure is fine, but then steadily starts going down again.
- 20 minutes later, the engine starts shaking hard, for a misfire. Then, after getting off the highway, the engine does auto-stop at a light, and then when restarts, no misfire.
- In city driving, no oil pressure issues, CEL light is on but not blinking.
What could this be after the f*****g $3k repair that the same thing happens again?
Is it the AFM system? It's a 6.0l V8 LFA Vortec with AFM on lifters 1, 4, 6, 7 on a 2008 Tahoe Hybrid 4x4.
Old Mar 19, 2021 | 6:35 PM
  #314
Melanie Hooey's Avatar
Default AFM Failure
Originally Posted by in2pro
Welcome to the forum. If you can get some pictures of the parts they take out or better yet ask for them back...would really like to see and understand what is failing and what the lifters and cam look like.
Just got my 2007 Avalanche back from my mechanic as I have encountered the same issues as everyone on here. My mechanic said he has never seen a camshaft so beaten down like this. There has to be some design flaw causing this issue. Needless to say I need camshaft and lifters but have opted to scrap it due to the high mileage and age of my vehicle. Sad because I really loved this truck.
Old Mar 20, 2021 | 4:32 AM
  #315
sfcjones's Avatar
The repairs for this motor even with high miles could be worth it. No payments for another truck speaks volumes. You mechanic can replace the lifters and camshaft with LS7 parts and disable the AFM. not super expensive and I think you will be happy. I know if I had your truck and I liked it that would be the route I would take.
Old Mar 20, 2021 | 4:44 AM
  #316
sfcjones's Avatar
for about 1k in parts and whatever the mechanic charges for labor you can fix this.
https://www.texas-speed.com/p-7379-t...2-engines.aspx
Old Mar 20, 2021 | 10:44 AM
  #317
Default AFM Faikure
Nah. The body is rusted out, huge hole in one of the rocker panels and tailgate. I may sell it to someone who wants to part it out. I have another vehicle so it is not like I am at a complete loss. Thanks though.
Old Mar 21, 2021 | 1:39 PM
  #318
sfcjones's Avatar
I understand. My 2007 Tahoe is in Mint condition. No rust, no dings, paint in real good shape. I have already did the work on mine and with almost 300k miles I will never part with it. no payments so it is something that is good. Even if the motor takes a crap I will get a new/used motor and for under 2k bucks it will be on the road again.
Old Mar 22, 2021 | 10:53 PM
  #319
Well this is cool.
Old Mar 23, 2021 | 10:54 AM
  #320
sfcjones's Avatar
Well this is cool.
It is however the problem still exist because the AFM lifters are still in place. They are the problem child in these motors. Replacing these lifters with lS7 lifters and the cam fixes everything.
