2010 Silverado 5.3 salling no codes
Old Nov 10, 2023 | 11:45 AM
magnum marine 27's Avatar
Default 2010 Silverado 5.3 salling no codes
I have a 2010 Silverado 5.3 that just started stalling along with a ruff idle, but has no check engine codes. A friend suggested disconnecting the positive batt cable for at least 30 min. When i Hooked it back up it was fine for about 3 days even towing my boat. Making me think that there was no mechanical problems. The problem came back so the next time I left the battery cable off over night & it was ok & I drove again ok for two days. This must a electrical problem that needs to be fixed. I would be grateful for any suggestions in making a permanent FIX.
Old Nov 10, 2023 | 4:22 PM
Did you run a full system scan, or you mean the warning light isn't on?
Old Nov 11, 2023 | 12:16 AM
I only have a basic code reader, like I said no codes .or any warning lights. It will run great for a few day after I disconnect the Battery for 30 min, but you never know when it will start stalling again. I might have to get a better system scanner if I cant find someone who has had a similar problem.
Old Nov 11, 2023 | 12:27 AM
Not necessarily. Resetting the computer just makes it ignore the sensors and run on default values for a little while.
Start with basic engine stuff. Air filter, fuel filter, inspect spark plugs & tailpipe. clean the intake. Check for vacuum leaks. Run some injector cleaner. Watch the basic engine live data with a diagnostic tool and look for anomalies. Is this a flex fuel engine?
Old Nov 13, 2023 | 5:58 PM
All your advice is good but why does it run fine for a few days ? Mechanical problems dont go away for a few days even towing a heavy load like a boat. I hate to think it will have to go to the Chevy dealer who can run test on the computer. Thanks for your imput.
Old Nov 13, 2023 | 6:50 PM
I thought I just explained why.
The mechanics of the engine are controlled by a computer.
Don't go to a dealer unless you want to be ripped off. They'll just make a laundry list of things to replace without diagnosing anything.
See an independent mechanic who has a good reputation in your city.
Old Dec 20, 2023 | 9:06 AM
Dan Tana's Avatar
I have a 2010 Silverado 5.3l and just had the same problem. Engine would start fine, run rough for a few seconds then stall out. Found the clamp was loose for the air intake tube by the air cleaner. The tube came loose meaning the air coming in was not going past the MAF sensor. Put the tube on tightened the clamp. Running like a champ. Cleaned the sensor with Mass air flow cleaner while I was in there. Hope this helps.
uk3
Jun 15, 2013 4:07 PM
rx8racr
Aug 31, 2010 4:18 PM
johnray2010
Jul 13, 2010 7:42 PM
pickupman
May 13, 2010 2:20 PM
EvansBlue
ROTM Winners
Apr 5, 2010 2:53 PM
