B0012-0D Airbag
Old Apr 23, 2023 | 4:20 PM
LMMguy's Avatar
Default B0012-0D Airbag
Trying to get the bubblegum guy to go away. The code i am getting is B0012-0D Right Front/Passenger Frontal Deployment Loop Circuit low resistance DCT high resistance. I have my battery unplugged so the description is off the top of my head
I pulled everything out and have access to the connectors under the dash to the driver and passenger side seatbelt restraints and the airbags.
I tested the resistance from the sdm connector to each line disconnected from the airbag and get about .3 to .4 ohms or resistance on each and no shorts to ground.
I am unsure where to go from here as i have no wiring diagram and airbag sdms are not something I just want to poke and prod at.
all tests were done with the fuses pulled and batteries disconnected.
The colors in the images do not reflect the correct wire colors.
Brent Weight
Dec 14, 2020 11:36 AM
RETIREDGUY985
HHR
Aug 28, 2019 8:26 PM
Joseph K Stewart
Jun 27, 2019 1:36 PM
Synaux
May 22, 2019 8:45 AM
Joel C
Aug 6, 2009 5:30 AM
