Can't tell if Transmission is going bad or bad module.
Old Jun 24, 2020 | 2:07 PM
Chris Carlson's Avatar
Default Can't tell if Transmission is going bad or bad module.
I have a 09 Silverado crew cab lt z71. Here a couple weeks ago I had to slam on the brakes. After that the truck seemed to of got a studder. I finally got home after limping it back 60 miles. The next day I changed all the plugs and checked all the wires. When it was done drove OK for maybe a block then started to shudder really bad the the trany stop working. Then later that night we to push it home and started up went right into gear and drove 4 blocks the quit again. We got it shoved the garage next day crawled under it checking for maybe a broke wire or something. Got done with that didn't find anything the truck backed out turned around in the street then backed up into the driveway. So I'm trying to figure if I need to get the tranny replaced or what.
Old Jun 24, 2020 | 2:35 PM
kevinkpk's Avatar
For a start, how many miles, and how is the fluid level?
Old Jun 24, 2020 | 2:38 PM
kevinkpk's Avatar
The old adage , if it won't go in drive, but reverse, usually doe's apply to a turbo 350.
Old Jun 24, 2020 | 5:24 PM
180k fluid was full. I had the fuild changed around 110k miles.
Old Jun 24, 2020 | 5:27 PM
When it works it works fine nice firm shifts. 6l80e
Old Jun 24, 2020 | 5:34 PM
kevinkpk's Avatar
Could be a shift soleniod. I'd replace the fluid before doing anything drastic.
Old Jun 27, 2020 | 11:39 PM
I'll try changing the fluid first. Changing the shift solenoid you have to pull valve body. Read someplace that it was better to change the whole valve body then just the soleniod and aftermarket one corrects stock imperfections.
sniper7
Mar 3, 2012 10:36 AM
03rubicon
Jan 22, 2012 10:41 AM
LanaJoyce
Jun 23, 2011 11:55 PM
switchback05
Jan 22, 2010 12:05 AM
Suthrnridin06
Mar 3, 2008 12:36 PM
