Check engine light questions
Old Feb 19, 2018 | 9:06 PM
Erin Burke's Avatar
Default Check engine light questions
Have 13 1500 i just picked up.
T he previous owner had put a K&N aftermarket air intake on which seems to be properly installed.
The truck has 109000 miles on it . My check engine light is waving at me and my question is this. Is it possible that the aftermarket would cause the dummy light or foul out an O2 sensor?
I am taking it in to be scanned and am aware of possible codes for O2 sensors but I am cautious to change it/them out when the root problem may be the intake!!
I plan on attempting to get 300000 out of this truck so I wanna start and continue correctly! !
Any ideas would be greatly appreciated!
Old Feb 19, 2018 | 10:40 PM
oilcanhenry's Avatar
Do you have4 any codes?
Old Feb 20, 2018 | 8:02 AM
Was the MAF sensor installed into the K&N system?
Old Mar 16, 2018 | 9:05 PM
04redCATeyes's Avatar
honestly, if you want to do it correctly. get a decent reader yourself and internet learn what all the “live readings” should be. dont just rely on if you have a stored code or not. if your taking it to a dealer to get the codes read then they obviously have the $5k diagnostic reader that shows them literally everything. do not rely on some auto zone punk showing you a code an shoving a part in your face all the time. live readings on a scanner will show you maf readings and sensor readings in real time and then some. it will show fuel trims, timing, and a bunch of other stuff that once you learn what they mean, you will know the true health of your engine. see ya
Old Mar 23, 2018 | 2:09 PM
stacy.clouter's Avatar
We just dealt with an engine light in our '13. Reader noted rear O2 sensor. When hubby changed it the sensor was fine, however the wiring was rubbing against the chassis causing the wire insulation to crack and the wiring to become corroded. Might be worth taking a look at if you do throw a code for O2 sensor before removing the intake, its relatively easy to access.
Old Mar 23, 2018 | 2:11 PM
The wire rub is aparrently relatively common!
