Cold start issue
Old Jan 13, 2019 | 10:52 PM
Colette Hayes's Avatar
Default Cold start issue
2008 Chevrolet Silverado 1500 5.3 liter vortec 4x4.
Rough idle (Signifigant bouncing rpm) for 15-45 seconds when cold started. Once warm it runs and idles perfect.
Not throwing any codes.
Was just at the mechanic for new AFM and normal valve lifters.
It has new machined heads and *new* intake and exhaust gaskets. New spark plugs.
Problem started 3 days after the $4000 repair.
The thottle body has been cleaned, idle relearned, codes reset my shorting battery terminals, sensors checked and mechanic has tried swapping "multiple components" and doesn't know what to do.
Wants to send it to a dealership for computer reflash and go from there.
Mechanic did do a unlit propane test at intake gasket, but I'm not sure if it was during cold start or after it had warmed up. I have video of how it sounds if there is a way to send it to you. Didn’t work to attach.
Looking for anything to help us troubleshoot this. Huge thanks in advance.
Old Jan 13, 2019 | 11:29 PM
oilcanhenry's Avatar
Sounds like might be a small intake leak that seals when engine is warm to me. Might be a good idea to re- torque your intake manifold and check everything for tightness.
Old Jan 14, 2019 | 8:48 AM
Thank you so much! Will definitely check into that potential issue. Much appreciated man!
Old Jan 15, 2019 | 9:10 AM
You are quite welcome..
