Old Aug 10, 2015, 6:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Transmission Guides
Print Wikipost
driveline clunk in 2013 silverado
Old Nov 2, 2014 | 12:22 PM
  #11
mb.gov's Avatar
Thank you for the good news, ChevyTruck55. It's great to hear of potential correction! I'll know soon if the Dealership in Austin where I bought my 2012 1500LTZ 4x4 gets similar results, as I too mentioned the discussions of "the yoke" I've found in this forum. I've had it in the shop since last Tuesday for another warranty item when the mechanism operating the sliding window from the cab to the bed failed, so I assume they're investigating my truck's "jolt and slam" phenomena.
Oddly, the 2015 Z-71 4x4 the dealer kindly loaned me has a lesser effect of the phenomena. Hopefully, the more owners express themselves about this topic the quicker a permanent correction is engineered and implemented.
Thanks again for sharing.
Old Nov 3, 2014 | 9:03 PM
  #12
spr63's Avatar
Angry Driveline Clunk Noise arbitration update
I used the Better Business Bureaus 'Auto Line Program' to file a complaint against Chevrolet and to go to arbitration. It was me against Chevrolet with their District Manager of Aftersales present, and Detroit on a conference call. Even with a video tape showing the problem, and what I thought was a strong case, I lost.
Here is the findings from the arbitrator:
"Because, as indicated above, it is not an intended operation of the vehicle, the clunk and hesitation can be considered a defect. However, in that the condition has occurred not only in this model of vehicle but in other vehicles including passenger vehicles and light trucks manufactured by Chevrolet, to the point that a technical service bulletin has been issued discouraging piecemeal repairs of the drivetrain, it can be classified as a defect in design. As the express general warranty as well as the drive train warranty for the vehicle relate to manufacturing defects in the parts and workmanship in the assembly of the vehicle, and not to defects in design, it is not within the jurisdiction of the Better Business Auto Line Program to render an award for the repurchase or replacement of the vehicle for such a design defect."
What is interesting is the fine print of the service bulletin #99-04-20-002H
"Note; Compare this complaint vehicle to a like vehicle. If the results are the same, this is a normal condition."
"If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition."
Chevrolet is admitting that there are problems not related to this bulletin. But we, as the little consumers against the big corporations don't have a chance unless we can afford to hire the best attorneys. And Chevrolet is not liable for defects in their designs.
Old Dec 12, 2015 | 12:03 PM
  #13
mb.gov's Avatar
Default Driveline - CLUNK - Chevy Engr'g with Purpose
Originally Posted by spr63
From the time I purchased my 2013 Z71 4x4 in February, I have had an occasional clunk when slowing down and then pushing back on the gas. My 2008 4x2 had this happen and the dealer replaced the yoke, and every 15 to 20k miles I would need to pack the yoke with grease. When I took the 2013 to the dealer for this they could not duplicate the problem, so did nothing. I took the truck to another dealer and they said the same think. Now I have a distinctive metal sound that has happened with this clunk. I went back to the dealer and they told me there was a bulletin that said this is caused by 'play' in the driveline and is normal. They said not to worry about it, but monitor it to see if there is a change. They also said that this is more prevalent in 4x4's and they can not grease the yoke.
It only happens between 20 and 30 mph. The metal clunk sound seems abnormal to me. Here are a few questions: 1. If it is normal play, why doesnt it happen all the time? 2. Why does it only happen between 20 & 30 mph and not other speeds? 3. Does the metal clunk fall into the same category as the other clunk I have? 4. Why dont all the Silverados do this?
DOESS THIS SOUND FAMILIAR?
Document ID# 1430424
2003 Chevrolet Chevy Suburban - 4WD
Information on 2-3 Upshift or 3-2 Downshift Clunk Noise #01-07-30-042B - (Jan 16, 2004)
2004 and Prior Light Duty Trucks
2003-2004 HUMMER H2
with 4L60E or 4L65E Automatic Transmission (RPOs M30, M32)
This bulletin is being revised to add the 2004 model year. Please discard Corporate Bulletin Number 01-07-30-042A (Section 07 - Transmission/Transaxle).
Some vehicles may exhibit a clunk noise that can be heard on a 2-3 upshift or a 3-2 downshift.
During a 2-3 upshift, the 2-4 band is released and the 3-4 clutch is applied. The timing of this shift can cause a momentary torque reversal of the output shaft that results in a clunk noise. This same torque reversal can also occur on a 3-2 downshift when the 3-4 clutch is released and the 2-4 band applied. This condition may be worse on a 4-wheel drive vehicle due to the additional tolerances in the transfer case.
This is a normal condition. No repairs should be attempted.
This notorious "CLUNK" is Chevrolet Engineering's design feature, at least for some of its vehicles. The above came from the forum in 2004.
Old Dec 12, 2015 | 12:12 PM
  #14
mb.gov's Avatar
2003-2004 HUMMER H2
Old Dec 12, 2015 | 12:15 PM
  #15
mb.gov's Avatar
Warning to light-duty truck buyers: Some new half ton trucks still CLUNK. It's a driveline defect Chevrolet engineers into these vehicles. It's been present in some light-duty vehicle for over a decade.
Here's Chevy's description (sound familiar):
2003-2004 HUMMER H2
Old Dec 12, 2015 | 12:18 PM
  #16
mb.gov's Avatar
BTW: Don't buy Service's explanation that it's a 6-speed transmission phenomenon. It's been around for a decade (or more).
Metal to metal, CLUNK, likely results in catastrophic failure. Pray your warranty is still in force.
Old Dec 12, 2015 | 2:47 PM
  #17
rene2398's Avatar
i have the same issue with my 2012 silverado since day one i bought new zero miles and they tell me the same **** it is normal i don't agree that that horrific sound is normal.. you described exactly the same issue i have ..
Old Dec 13, 2015 | 8:44 AM
  #18
ChevyTruck55's Avatar
Spr63, I bought a brand new 2014 Silverado crew cab, it does the same thing as my 08 use to do but, not as often and a lot less noise when it does do it.. I did also make a post of this problem with the 08 Silverado I owned. When I had it I got the same actions you got chrome yoke and packing of yoke with a heavy duty grease.
Should they do something, yes. Will they do any thing,no. I hope they get it squared away for you soon.
Chevy
Old Mar 29, 2016 | 8:28 PM
  #19
twidgeon's Avatar
Default Has everyone contacted the Better Business Bureau
I've had the same issue with my driveline. There is a noticeable clunk/jolt in the driveline when accelerating after slowing while driving. I brought my vehicle in and the technicians acknowledged there was definitely a noticeable clunk and tried to reprogram the TCM. That didn't work. So I brought it back and they looked at the yolk, it was ok. The "bulletin" was found after trying to fix the clunk problem so they wouldn't work on it anymore.
I've contacted the BBB and have an open case for this problem.
If you haven't, please take the time and open a case with the BBB is you are having this issue.
Contact your local BBB representative at this site.
Find A BBB
Hopefully we can get this issue resolved together!
Old Mar 30, 2016 | 12:41 PM
  #20
spr63's Avatar
63,000 miles on my truck now and I still have the driveline clunk problem. I lost my case using the BBB. See above thread for the ruling. All Chevrolet says is I have a 100,000 mile drive train warranty, in case there are any problems. I just hope that if I have any problems, it happens before the warranty expires. If anyone was won a case against Chevrolet for this problem, please let us know how!! Maybe time for a class action suit.
