Driver side power window
Old Jan 22, 2022 | 12:20 PM
Jasonm's Avatar
Default Driver side power window
I have a 2012 chevy silverado 1500 the drivers side power window stopped working. I have replaced the master switch twice in case the first ine was bad, replaced new window and regulator and replaced circuit breaker thats behind the fuse box inside the truck and still no luck. Looking for help.of what else I can check.
Old Jan 22, 2022 | 3:07 PM
kevinkpk's Avatar
Regulator is bad will cause the window to not stay up. Bad motor?
Old Jan 22, 2022 | 3:54 PM
Jasonm's Avatar
i have replaced the regulator and the motor already and if i apply direct power to the motor it works.
Old Jan 23, 2022 | 12:18 PM
meternerd's Avatar
Check for a broken wire at the hinge side of the door. Flexing can break wire but leave wire insulation in tact, so it looks OK. You'll probably need a voltage tester and a wiring diagram.
Old Jan 23, 2022 | 4:29 PM
Jasonm's Avatar
okay that sounds like its viable, i will check and let you know.
thanks
Ke'aloha Crytser
Oct 16, 2020 1:30 PM
justin69
Feb 28, 2015 2:54 PM
RSDP 1227
Jun 21, 2011 9:37 PM
jtlonghorn
Sep 5, 2007 11:20 PM
98greenventure
Apr 1, 2007 3:15 PM
