DTC P0336 RPM drops to zero
Old Apr 11, 2024 | 6:27 PM
achvloy's Avatar
Default DTC P0336 RPM drops to zero
My 2009 sierra has been having the same problem. Starts up fine but eventually when your driving stabilitrak and traction control comes off and the rpm just drops to 0. When that happens it starts to drive rough and kick sometimes. Then it fights me trying to start up, it even stalled on me when it happens.
Old Apr 11, 2024 | 6:42 PM
There are hundreds or thousands of things that trigger the check engine light. You need a diagnostic scan to see what your particular fault is.
Old Apr 11, 2024 | 6:44 PM
achvloy's Avatar
Default Code
P0336, thought i had put it in. My mistake
Old Apr 11, 2024 | 6:50 PM
Try the 'Possible Solutions' here: https://www.obd-codes.com/p0336
