Dual Climate control
Old Dec 7, 2022 | 2:35 PM
Zebbys17's Avatar
Default Dual Climate control
I have a 2012 Silverado LTZ and blowing cold air out of Pass. side and hot out of the drivers. Any thoughts?
Old Feb 24, 2023 | 12:26 AM
arho1775's Avatar
Sounds like the blend door is bad/ stuck, I would look into replacing them because that’s what controls what air goes where’s and the temperature as well. There is 3 different ones, one for her driver side vents, passenger side vents and usually in the counter that controls the temperature. Sounds like you have cold and hot air but the vents are blowing out two different temps at the same time so I would def change the blend door actuators
Old Feb 24, 2023 | 9:02 AM
ditto. bad temp blend door actuator or stuck/broken blend door. if the doors and door motors are good...partially blocked heater core is another possiblity
Aug 9, 2014 10:06 PM
warden48
Jan 11, 2011 3:35 PM
tj6675495
Nov 21, 2010 4:52 PM
Joepoppa1
Oct 4, 2009 11:20 PM
Larryrb
Jul 1, 2009 2:27 PM
