Engine shutting off
Old Apr 5, 2019 | 4:40 AM
11ltz1500's Avatar
Default Engine shutting off
I have a 2011 1500 LTZ 5.3 and noticed the other day I was making a sharp turn going about 3mph and my truck bogged out and lost oil pressure then shut off. I put it in neutral and turned it back on. Now it happens every time I make a turn or come to a stop. Can someone please tell me what could be wrong. It'd be really appreciated
Old Apr 5, 2019 | 7:43 AM
harveyspecter's Avatar
To see what causes engine stalling click here
Hi!
Did your engine speed (RPM) droped very low when the oidl pressure droped? Is this happening only when you fully release the throttle? If so, you might have a bad idle control valve or a dirty throttle body.
Old Apr 5, 2019 | 1:01 PM
Maybe the power steering is going out and it's loading down the engine too. Hydroboost brakes I'm guessing.
Old Apr 5, 2019 | 7:30 PM
11ltz1500's Avatar
Originally Posted by harveyspecter
Hi!
Yeah the rpms dropped so did the oil pressure, it happens once I go over 40 then stop or stop to quickly, but I can fully release the throttle if it doesn't shut off
