Headlight Problem
Old Oct 31, 2017 | 5:53 PM
brentalight's Avatar
Default Headlight Problem
Tried replacing the low beam bulbs in my 2012 Silverado today. The drives side was out. Got the install done and all appeared good. I shut off the truck and then used the key fob to check and see if they came back on. The drivers side wouldnt come on. I was able to wiggle the wiring harness and it came back on but using the fob it happened again. This happened multiple times and also caused the passenger side to go out a few times. Wiggling that one also brought it back to life. Is this a bad wiring harness or could this be a relay problem?
