High beam lights
High beam lights
I have a 2010 and the other day both high beam lights stopped working at the same time. I checked and it’s not the bulbs. The indicator light on the dash comes on but the but not the two lower headlights. Any ideas where to start?
Thanks in advance
Thanks in advance
I had this happen in my 08 and it was the under hood fuse panel itself. It’s actually a computer board inside there and some corrosion took out the high beam relays which are soldered into the board instead of a removeable relay
