How do I fix random misfiring
Old Jul 30, 2023 | 9:07 AM
jacksonduper's Avatar
Default How do I fix random misfiring
2012 Chevy Silverado 2500HD
I’m getting a p0300 code
Error Code P0300 indicates cylinder misfires. The letter P indicates an issue with your vehicle's Powertrain
Should I replace spark plugs, wires and all ignition coils? Truck has approx 110,000 miles on it.
thanks in advance.
joe
Old Jul 30, 2023 | 9:26 AM
Rednucleus's Avatar
When was the last time you did a full tune up?
Old Jul 30, 2023 | 10:52 AM
many things can cause misfiring. Best thing is to gather as much data as you can so you're not firing the parts cannon and chasing dead ends. Try to get a misfire count on each cylinder, and note down fuel trims for each bank. Visually inspect the spark plugs.
Old Jul 31, 2023 | 9:51 PM
rcorn1031's Avatar
Banned
Default Re “How do I fix random misfiring”
thanks in advance.
joe
Like others have stated . Before shooting the Parts Cannon at this issue , Check each and EVERY ground connection between the Engine and chassis ,Engine and body , and Frame and engine and the Battery Negative cable and the Engine . for Cleanliness , Tightness , and completeness . If they are corroded they need cleaned down to clean metal . After clean apply an anti-corrosive compound that does Not harden.( I use “Truck-Lite NYK-77”) Lacquer based terminal preservatives when hardened will crack from vibration and allow corrosion to recur . After you have performed this critical task check the terminals on the ignition relays for corrosion . Same process here . Clean and apply preventative compound . to the stabs and sockets . I used Q-tips for this process .
All of this does take time but it will help eliminate weak or intermittent grounds that can cause such misfires . All of the Injectors and Ignition coils require solid ground connections in order to function properly .
Tavo Govea
Jan 13, 2025 3:10 PM
carlasdaddy
1988 - 1998 (GMT400)
Feb 23, 2023 10:49 PM
Roger247
May 7, 2021 1:15 PM
halfasemitone
Aug 18, 2012 12:49 PM
awc
Oct 17, 2010 8:14 PM
