intermittent airbag light
2010 Silverado quad cab
Would anyone happen to have the location of all the airbag sensors for my Silverado? I've looked as many places on the internet that I can think of and can't find anything about others than the 2 front collision sensors. Any help is greatly appreciated.
are you getting a warning light or something?
Yes I am. I have had it cleared, and then I my son was moving around in the back seat, and the light was going on and off. So I'm not sure where it is. I would just like to have a diagram of all the locations just for future reference.
cleared what? Was there a trouble code?
which light? If it's a passenger presence light then that would be normal.
If it's a malfunction light, then it could have something to do with the restraint or presence system in the seat. Make sure the connector going to the seat is pushed all the way in, and that there's no corrosion or contamination inside it.
By cleared I meant the light turned off.
My son was in the rear seat, middle, and if he bounced just a little it would turn the light on. Did it 2/3 times. Is there a diagram to show where the sensors are located, so if I need to replace it, I'll know where to look.
running a diagnostic scan will tell you why the airbag light is illuminating.
Did you check the seat connector like I suggested?
vancuren77@gmail.com
August 29th, 2010 4:22 PM
RandyD123
August 26th, 2010 6:22 AM
ylee kyotee
March 7th, 2010 5:05 PM
