Leaf springs
Leaf springs
Hey. I just recently had 2 leaf springs crack on my chevy silverado 07. Drivers side i lowered gas tank. Took off trailer hitch and took off the spring. The bolts were insanely hard to remove from the rubber in the springs. So for the passenger side i was going to only change the smaller 2 leafs and keep the big one on so i do nit have to remove them. Thus saving me alot of work. Driver side springs that i am using to replace it came off from another truck similar to mine and i have the matching set. Since i changed the whoke left side springs for the used part. And im only changing the 2 bottom leaf's and them pitting it back together. Does it matter that the 2 big leaf springs with the bushings are not the matching set. One being new i just out on and the other side sticking with original spring and swapping bottom 2. Will it make a difference in my suspension? Is it bad for my truck? Is it okay if i do it this way? Any recommendations or comments are very much appreciated
you should be fine. I have changed individual leaves and noticed no change in handling or ride height. you might want to have the alignment checked afterwards. ride height changes will effect toe settings.
trucker9
February 9th, 2014 8:52 AM
