Misfire
Old Mar 10, 2024 | 4:40 PM
#1Gearhead's Avatar
Default Misfire
2010 gmc sierra 4wd 5.3l LC9. Afm/dod engine. Lifter stuck on cylinder 4 replaced all lifters back to factory. New head gaskets intake gaskets plugs wires oil change new coolant. Now sets a random misfire code. Scanner shows 1,4,6 misfiring. Swapped all ignition components with other cylinders. misfire didn’t move. Ran with valve covers off watching the valves and they all open and close. Performed Crankshaft relearn. Still misfires. Any help is appreciated. Thanks
Old Mar 10, 2024 | 4:57 PM
did you take a look at the camshaft before replacing the lifters?
Old Mar 10, 2024 | 5:41 PM
#1Gearhead's Avatar
Yes. It looked good and so did the roller on the lifter.
Old Mar 15, 2024 | 8:26 AM
JamesGee's Avatar
Any update?
Old Mar 15, 2024 | 11:51 AM
#1Gearhead's Avatar
Right now I am down to the vlom being the culprit. I removed it and bench tested oil circuits and they are leaking past the gaskets into the channel that unlocks the lifters. So now I am waiting for the new one to come in.
Old Mar 22, 2024 | 1:30 AM
JamesGee's Avatar
Ok, thanks.
Old Mar 22, 2024 | 11:57 AM
#1Gearhead's Avatar
Originally Posted by JamesGee
Ok, thanks.
installed new vlom and all is good. Thanks!
Ondemandhandyman
May 20, 2022 11:30 PM
Hellblazer73
Nov 16, 2021 12:30 AM
Tony Tiller
2007 - 2013 (GMT900)
Dec 14, 2020 12:06 PM
Invisions1
Dec 4, 2020 6:37 PM
Biggumzmcgee
Nov 15, 2009 10:51 AM
