Oil Leak
Old Mar 2, 2016 | 10:21 AM
DVAKTK's Avatar
Default Oil Leak
I have recently purchased an 08 Silverado, 4 wheel drive, extended cab with the 5.3 engine. The bottom is very clean except the area above the oil filter. Just above the filter is a cover with two bolts holding it and I cannot determine what this is or what it is for. It appears to be the source of the leak. Any thoughts or help would be appreciated.
Old Mar 2, 2016 | 7:25 PM
cleveland63b's Avatar
its where the oil cooler lines hookup to the pan, there is a gasket there that sounds like is probably your problem
Old Mar 3, 2016 | 10:22 AM
DVAKTK's Avatar
Thanks cleveland63b...Is this a fairly common leak area? Will I have to drain the oil to change the gasket? What would you recommend as a good reference book of info on this truck?...if any?
Old Mar 3, 2016 | 7:58 PM
i wouldn't say real common but I've seen it a handful of times. No you won't have to drain the oil you'll lose a little when you unbolt it but not much.
As far as a book I've heard Haynes and Chilton are decent but I have no personal experience with them, I've always had access to online service information through my jobs.
