Trying to figure out if this is my rear main seal leaking, been having oil droplets forming coming between the engine/trans bellhousing, I took the inspection port off the bottom, and I can see there is oil leaking down from infront of the flywheel, is this guaranteed to be my rear main seal? Circled part of image is where i can see oil coming down infront of flywheel
