Started my 2008 Silverado with the 4.8L and I got some vibrations and a flashing engine light. Pulled the codes and got P0300 random misfire and P0351 ignition coil A circuit malfunction. I have identified the issue, the harness going to the ignition coil has broken. My question is, can I also disconnect the injector for that cylinder and run on 7 to get it to a shop or do I absolutely need a tow? Where the connection broke The broken connection
Reason: Edit title for accuracy
