Power mirror help
Old Jul 9, 2019 | 4:45 PM
Christeachey's Avatar
Default Power mirror help
2007 silverado. I replaced my factory mirrors with after market towing mirrors. Everything worked as it should. Worked well for 3 months.The other day, it blew the 2 amp fuse in the truck. Replaced switch, put new fuse in.
If I switch to passenger side and hit the adjust button, it blows the fuse immediately. If I select the driver side and hit the adjust button, it moves both the driver and passenger side mirror. But it only moves the passenger side mirror in....not out.
Any suggestions?
Old Jul 9, 2019 | 5:12 PM
Any suggestions?
I hooked up the original mirror on the driver side...does the same thing.
Old Jul 9, 2019 | 6:36 PM
Well.....I fixed it. Lol
So others will know...
I hooked up the factory driver side mirror.....it did the same thing.
Hooked up the factory Passenger side mirror...problem went away.
This told me it was the pass. Side tow mirror.
Followed the wire from the plug to the mirror, and found a very flat spot on the wire loom. Pulled it back, found a cut wire. Fixed the cut wire, problem solved.
