power window switch driver side not working
Old Jun 8, 2017 | 7:07 PM
Mpmurphy27's Avatar
Default power window switch driver side not working
2013 Silverado crew cab
Old Jun 9, 2017 | 7:30 AM
Replace it! I have taken these apart before very carefully and cleaned the contacts and they started to work again.
Old Jun 9, 2017 | 6:42 PM
intheburbs's Avatar
It's a known issue that they're not very well protected against water ingress. Going to drive-thrus in the rain, opening the door in a heavy storm, etc. will allow moisture to get in and the switch contacts get corroded.
You can either buy a replacement or troubleshoot your existing unit and try to clean it up. Personally, I don't have the time to mess around with that kind of thing. I'd just buy a replacement.
Old Jun 16, 2017 | 1:56 PM
meternerd's Avatar
How do you know it's the switch. Could be a break in the wiring near the door hinges. They flex every time the door opens.
