Running hot only when the heat is on
Old Oct 25, 2017 | 6:05 AM
K.K.'s Avatar
Default Running hot only when the heat is on
Can any one please tell me why my '11 runs hot only when the heat is on?
Runs fine any other time and with the a/c on.
Just had the water pump, master cylinder, brake booster and heater hose replaced.
Thank you!
Old Oct 26, 2017 | 8:16 AM
-idling and driving this occurs?
-can you put a scan tool on it and get some actual coolant temp data...knowing the numbers would be helpful.
