Seat swap airbag issue
Old Jul 29, 2016 | 2:34 PM
roempty's Avatar
Default Seat swap airbag issue
Hi I have a 2010 Silverado 1500 LT. Cloth seats power driver side manual passenger side. Bought set of power seats passenger and driver side 08 Yukon Denali. Went to do with a seat swap knew I would have to make some wiring changes Wired the seats up all the power functions work no problem but the seats have no side airbags built in. I have one plug the yellow plug connector with two wires that I believe is the airbag sensor. Is there anyway that I can wire this or bypass it to get the airbag light off of my Dash
Old Jul 29, 2016 | 8:33 PM
at the connectors....the abs module must see a resistor the same ohms as what the air bag was.
Old Jul 30, 2016 | 4:24 AM
roempty's Avatar
Can a plug be made or a resistor wired between the leads? Do you know what resistance it is? Or where I can find info. Can I remove out of old seats. Thanks in advance for help.
Old Mar 21, 2017 | 7:58 PM
Dick Grubbs's Avatar
I also have same issue, was your problem answered here?
