Stabiuli-WHAT?
Old Dec 23, 2016 | 7:57 PM
rodbuilder's Avatar
Default Stabiuli-WHAT?
Yeah, all of us who were naive enough to buy one of the 2010 or newer Chevys with their "Stabilitrack" "Traction lock" garbage on it has no doubt encountered that triangle-shaped error light on the dash, along with the impossible-to-remove "warning" on the digital read-out.
Ya see......these are 2 of the "engineering achievements!!" GM has made to their vehicles that the salesman kinda "forgets" to explain to you when he takes you out on that test drive!!! And even if he does, there's no way in hell that he's gonna' tell you how much it costs to fix this unnecessary garbage WHEN (not if) it goes bad!!!
SO..............Mr. Chevy God, PLEASE tell me how I can blow all this crap out of my truck and return it to a normal, driver-friendly put-it-in-gear-and-drive-it 4x4? I figure it this way - someone made this P.O.S., so I'm thinking that there must be someone out there who is smart enough to know how to eliminate these 2 over-engineered pieces of engineering garbage from my otherwise nice 2011, Texas-born, Silverado, 2500 HD 4x4.
I HATE this crap, so lay it on me - how can I PERMANENTLY (note the word permanently?) kill the T/L and Stabilicrap "options"? New BCM? Re-program the BCM? And is there a way to do this and also eliminate the messages associated with those 2 "options" on that digital read-out on the dash- you know, make the computer think that the TL and Stabilicrap isn't even on this truck??
I guy at a boneyard told me today that if I pull the ABS fuse it will disable these things, but (obviously) the ABS light will be on, and my dash is already lit up like a frikkin' christmas tree already, so I really don't need another error light staring me in the face!!
OH and if anyone at GM is reading this, PLEASE stop putting this crap on our vehicles, because we REALLY don't need your "help" to drive our cars. We really don't want to pay extra for a vehicle that thinks we don't know how to drive it!!!!
God I hope someone has the answer to this!!!!
Old Dec 24, 2016 | 8:49 AM
Default stay calm
abs, traction and stability control is federally mandated on all new vehicles nowadays...so you will never get away from it.
It is easier to fix it than to disable it. You are better off with these systems functional anyway.
have the powertrain and body codes read and post them here. It could be something simple as a bad wheel speed sensor.
Old May 15, 2017 | 11:36 AM
2011silveradolt's Avatar
I have a 2011 Silverado 1500 LT Z71 4X4 with 90,000 miles on it. Last Friday I had the transmission, both differentials and the transfer case serviced. On Monday I was on my way home from work driving straight at about 25 MPH and I got the dreaded chime with flashing SERVICE TRACTION CONTROL, SERVICE STABILITRAK. I did not have a reduce engine power warning. So I continued to drive it back to the service shop and had them check the fluids. I verified with them all was good with the fluid levels. I had no hard shifting and no lack of power during the drive. I had this light once before after installing my lift kit and it was because of the connector at the front transfer case. So I then decided to shut my truck off and completely remove the connector and then reinstall it. I started it up and boom the warning were gone. So I thought okay we are good, well nope. A few days later around the 100 mile mark it happened again so I pulled the connector and put it back and all was good. Can someone tell me what is going on with this?
