Transmission in limp mode
Old Dec 22, 2019 | 11:15 AM
Downingm6's Avatar
Default Transmission in limp mode
Hey, I’ve been having some issues I’m hoping somebody might be able to help with. I have a 2013 Chevy Silverado 1500 and it started with the transmission being in limp mode, not shifting out of 2/3 gear with a P0700 code. I could shift into manual and shift normally for a while until it would revert to the same low gear. I took it to the dealer who said it was my battery and negative battery cable, replaced, same problems. Only now I get a P2534 ignition switch code. I had the alternator tested and it’s good, I took it to a transmission specialist who said it’s just the ignition switch that needs to be replaced. So I replaced the ignition switch only to continue to have the same problem. Has anyone had a similar experience? Do I need to replace the ECM? Help!!!
Old Dec 14, 2020 | 9:01 PM
Michael Harper's Avatar
Default Help!!!
Dude please tell me you have solved your problem. I am littleraly having the same issue word for word. I have now replaced the TCM ,ecm, battery's , ignition switch. . And all of the trans selinoids. And I am still having the issue . Please tell me yours was resolved and how !!
Old Jun 23, 2022 | 1:13 PM
TSMATHEWS72's Avatar
Unhappy Limp mode
i AM HAVING THE SAME ISSUE, HAS NO ONE SOLVED IT YET? PLEASE HELP!!
Old Aug 29, 2023 | 8:15 PM
Bmauk's Avatar
Default Anybody
Has anybody figured this out ? I'm having same problem and can't figure it out
Old Aug 30, 2023 | 12:14 AM
You need a full diagnostic scan to read the faults from the TCM. Take the vehicle to a transmission specialist.
Old Sep 14, 2023 | 8:41 AM
ssgcallen's Avatar
My 07 had these exact issues, i swapped starter, alternator, fuses, and most relays except for the run/crnk. Turned out to be a TCM and Run/Crank relay replacement.
jd830steve
Jul 30, 2017 7:55 PM
hakongroven
Apr 8, 2014 2:23 PM
metal7654
Dec 5, 2012 9:31 PM
cricket
Apr 7, 2011 4:02 PM
don08
Oct 30, 2010 8:00 PM
