Truck Overheating
Old September 26th, 2019 | 8:36 PM
dpwilson3's Avatar
Exclamation Truck Overheating
I have a 2010 Chevy Silverado. My truck started overheating when I leave it idling for 10 - 15 minute periods. Once I start driving the temperature usually goes back to normal and the AC turns back on. Now it’s at a point where the temperature isn’t going back down to normal and I’m losing power to the engine. I replaced both the thermostat and the temperature sensor and the engine is still running hot. Any help or suggestions as to what else I could be dealing with would be greatly appreciated. Thanks.
Old September 26th, 2019 | 8:43 PM
Doug D's Avatar
Check the fins on the radiator. See if any are missing or damaged. My guess is the radiator no longer effectively removes heat. It may be scaled up inside. If so, it may need replacement.
dpwilson3 (September 26th, 2019)
Old September 27th, 2019 | 8:08 AM
sounds like a problem with the radiator fan. It should be spinning full speed when your temp is too high.
Jay Wells
September 18th, 2019 12:50 PM
powell0819
September 3rd, 2016 8:40 AM
Jacksonojsparrow
July 22nd, 2016 2:12 PM
penet05
Uplander
12
May 13th, 2012 11:55 AM
SuperTexan
December 29th, 2008 9:42 PM
Quick Reply: Truck Overheating
