Wire terminal type on end of wiring harness
Old Apr 20, 2017 | 2:16 PM
mbushman1's Avatar
Default Wire terminal type on end of wiring harness
I am working on my 2007 2500 4X4 Suburban and wanting to switch over to electric radiator fans it has all the relays and fuses already to go in the fuse and relay box under the hood but they did not run the wires from the fuse and relay box down to where the radiator fans will mount. I need to know what wire terminal to buy to connect into the bottom of the Relay box. I thought it was the Metri pack 630 series connector but that did not fit correctly. I am hoping someone will know what kind of wire terminal that is. I have attached a couple of pictures of the end of the wiring harness connector that the wire terminal will need to connect into. Any help with this would be much appreciated.
Connector that i need Terminal to snap into
This is the connector that plugs into the bottom of the fuse and relay box
