Won't start
Old May 19, 2016 | 9:48 AM
Restlessone's Avatar
Default Won't start
I have a 2007 Silverado 1500 Ext Cab. It has the 5.3 ltr engine and about 200,000 miles
I drove the car to an appointment, was there for 4 hours and when I came out the truck would not turn over. Dash light all came on and when you turn the key on the is a very hard to hear clicking noise like a relay is trying to work. There are no codes. I installed a new battery and there is no change.
I don't even know where to start looking, Help.
Old May 19, 2016 | 10:44 AM
Check the battery cables for loose or corroded connections on both ends of the cables. Check the connections at the starter.
Old May 19, 2016 | 9:51 PM
cleveland63b's Avatar
have someone hold the key in the crank position and try tapping on the starter, either the starter is bad or you have a connection issue from the sounds of it.
Old May 20, 2016 | 12:26 PM
Done all of the above. Guess the next thing to do is buy a new starter.
Thanks for the suggestions
Gord
