2014 chevy silverado stiff brakes
Old Jan 16, 2024 | 1:55 PM
David6021's Avatar
Default 2014 chevy silverado stiff brakes
So I recently did my brake booster and master cylinder now I have no brakes it lags to stop and has a stiff cylinder
Old Jan 16, 2024 | 2:53 PM
did you bench bleed the MC?
Did you perform an ABS system bleed using a bidirectional diagnostic tool?
Old Jan 16, 2024 | 6:42 PM
David6021's Avatar
I did do the bench bleeding not the abs bleeding now is that something I could do at home or does it need to go to the dealership?
Old Jan 16, 2024 | 9:46 PM
it doesn't need to be a dealership (and they would probably charge the most), but it needs to be someone who has a professional grade tool.
Old Jan 20, 2024 | 3:20 PM
David6021's Avatar
I did everything I have this code c0273-05 brake level switch high voltage/open replaced the sensor and deleted code but keeps coming back within 30 seconds
Old Jan 20, 2024 | 4:18 PM
Originally Posted by David6021
I did everything
what's "everything"? 🤷‍♂️
trouble codes are not part shopping lists . It's telling you there's a fault condition on a circuit, so you need to troubleshoot and find it with schematics and a meter.
Old Jan 21, 2024 | 9:44 PM
David6021's Avatar
I checked the connector with a meter there is voltage and everything seems fine
rudawg79
Aug 9, 2023 8:52 AM
Sbaylajf
1988 - 1998 (GMT400)
Jun 23, 2022 1:35 AM
Trailblazer Sucker
Apr 29, 2022 6:55 PM
Fishingfreak1988
May 15, 2017 9:06 PM
steph66
Jun 10, 2009 10:38 AM
