2014 Silverado, getting a "tighten gas cap" message on dash after new fuel pump
Old Mar 7, 2026 | 2:19 PM
Fen Jagoda's Avatar
Default 2014 Silverado, getting a "tighten gas cap" message on dash after new fuel pump
Hey all, I hope this hasn't been asked before, if so I didn't see it.
I just got the fuel pump replaced on my 2014 Silverado 1500, had some rust holes in the metal plate on the top of it, have gotten a "tighten fuel cap" message twice now well going up a small hill on my road, no check engine light or anything just the message. I tightened it after the first time and just gave it a good cleaning, hopefully that solves it but if not what else should I check? The shop is a local place run by complete ******** so if I don't have to take it back that's preferable lol.
Old Mar 7, 2026 | 3:07 PM
Welcome from Florida. It is possible that there is an air leak at the fuel pump. The o ring may not have sealed correctly. Since it started after the fuel pump was replaced, I would there first.
Old Mar 7, 2026 | 3:24 PM
Fen Jagoda's Avatar
Thanks for the advice. Guessing I'd have to either drop the tank or take the bed off for that ha? Check engine came on after driving a bit more if that changes anything (checking the code now)
Edit code attached below. P0455, Large leak
Old Mar 8, 2026 | 1:13 PM
Doesn't change anything. There is a leak somewhere which started after the pump replacement.
Old Mar 8, 2026 | 1:37 PM
Rednucleus's Avatar
Maybe just a big coincidence, but have you tried something easy like a new gas cap? And I assume you were getting the message before pump replacement??
Old Mar 8, 2026 | 2:23 PM
Fen Jagoda's Avatar
Gas cap is less than a year old, gm official part clicks just fine and I cleaned it to make sure that wasn't it.
As for messages nope, absolutely none actually. Nothing on the dash or any codes before.
oceanstatewitch
Silverado DIY and Useful Threads
Aug 2, 2025 8:38 AM
mattyhaden69@gmail.com
Captiva
Apr 6, 2022 5:06 AM
dgriffith
Mar 11, 2015 12:46 PM
Vanilla
Jun 8, 2013 6:45 PM
stuffedbackseat
Jun 25, 2012 2:06 PM
