2015 2500 HD Duramax Upper Control Arm Camber Bolts
Old Mar 12, 2022 | 11:51 PM
15 Duramax's Avatar
Default 2015 2500 HD Duramax Upper Control Arm Camber Bolts
I recently installed Zone upper control arms on my 2500 HD . A few weeks after install I saw a video on Youtube that spoke about blue and silver color coded camber bolts and their proper placemenrt.. I went back and rechecked and did find I had blue and silver variations. I did not pay close enough attention at the time and want to make sure I have them in the right configuration before I bring it for a front end alignment. I currently have both sides installed with the bolt heads on the inside of the shock wells and the nuts for each bolt forward and rear. As for the colors, the driver side is now blue in the rear and the passenger side is blue bolt in the front. Do I need to change anything.
Second question: Is there a tool or trick to install the small cam guide pins.
Thanks,
Joe
Old Mar 13, 2022 | 9:45 PM
Welcome to the forum. I'm moving your post to the Silverado section of the Forum where it will get more views as this is the welcome new members section. 😊
