2015 6.2l 1500 high country throwing misfire in cylinder 5 code
Old May 6, 2021 | 3:24 PM
Jesse Matthew's Avatar
Default 2015 6.2l 1500 high country throwing misfire in cylinder 5 code
Hey all so this trucks been a real head scratcher it first was throwing a misfire in cylinder 5 and a rough cold start idle code. I've replaced plugs,wires,injectors,manifold gaskets, high pressure fuel lines and have pressure tested cylinder 5 with 150lbs holding solid which resolved the rough cold idle start but still showing the misfire in cylinder 5. Kind of at a loss and looking for insight
Old Oct 8, 2021 | 1:27 AM
Hunterhog21's Avatar
Default Help
SAME EXACT PROBLEM .. mine is a 2018 , replaced everything you stated as well , did you ever get it fixed ?????
Old Oct 8, 2021 | 1:49 AM
Default Yes its costly
yup I did my friend unfortunately it was cam and lifters cylinder 7 wasn't closing all the way (afm shutdown) causing cylinder 5s lifter to collapse meanwhile cylinder 7s lifter scratched the **** out of the cam
Old Oct 8, 2021 | 12:12 PM
Honestly that’s fine ! My engine is down to the bare block rn , I already have a stage 2 BTR cam with DOD delete , this gives me hope !! My truck has been broke for 2-3 weeks , and dealer won’t work on it because it has a Cold air intake and voided warranty .. bs
Frank Leal
Aug 20, 2024 8:21 PM
Invisions1
Dec 4, 2020 6:37 PM
ill4na8na2
Jan 9, 2016 12:48 PM
a_kraker99
Nov 6, 2012 9:25 AM
Blackout51
Oct 20, 2012 4:36 AM
