2015 Silverado
Old Jul 7, 2019 | 2:24 PM
Don17's Avatar
Default 2015 Silverado
I have a 2015 Silverado when i start truck makes a sound like it has an exhaust leak. Took it. In for that was told it had no exhaust leak. Only make sound when i start truck then goes away. Anyone have any idea why this is happening. Truck runs fine just make noise when starting.
Thank you
Old Jul 12, 2019 | 11:18 AM
Irish_alley's Avatar
I'm here for the party
could be a leak that only happens when the pipes are cold then once it warms up the metal expands and seals the leak. with the engine cold i would try to feel around the exhaust to see if i could feel and air being pushed out
Old Jul 12, 2019 | 11:22 AM
Don17's Avatar
I took it to an exhaust shop and they couldnt find anything.
Old Jul 12, 2019 | 1:28 PM
KChevy75's Avatar
Is this in the engine area or the pipes?
You might have a broken exhaust bolt or bolts. When the manifold heats up and expands, the leak is closed.
Check your plugs as well and make sure none are loose.
