2015 Silverado dies at idle.
Old Aug 2, 2019 | 12:20 PM
rickyr30@hotmail.com's Avatar
Default 2015 Silverado dies at idle.
Truck dies after being on about 20 seconds. Rpm drops and it just dies. After looking under the hood I hear a slight whistling sound which leads me to a possible vacuum leak. My main ? Is where are all the vacuum lines to check ?
Old Aug 4, 2019 | 6:28 AM
oilcanhenry's Avatar
I'd wager you DO have a vacuum leak. Yeah finding a good vacuum connection is not easy on the newer motors. You can adapt the power brake hose to work however. You can spray some kind of liquid like WD-40 on the manifold, or some Naptha cleaning solvent, since I am not going to recommend using gasoline, although diesel fuel would work with less chance of a fire. If it changes the RPM's at all, you have a leak.
